Link lenghts 257mm wb
Desmo
Norway
I'm doing a build with a 257wb and need some longer links to achive this wb.
Do you know if there's some standard links I can use, or is the best option to make my own?
The CMX kit should include the links for 242mm and 252mm wheelbase. Your 257mm is about 3/16" longer than the 252mm. Add a 3/16" spacer to the rear axle links or build your own. From information I've seen, the stock links are a little weak and it might be an idea to build your own and get the length you're looking for plus the added strength of metal links.
The parts tree with the pivot balls should have some 5mm spacers. You might be able to add those to the rear links and be pretty close to 257.
