T_Tank
Its been a long time coming but here is my 3D printed LJ80/81
Firstly the picture that got me started down this rabbit hole and no its not mine but it looked least to me rather tough. What I didn't know was how tiny these trucks are!
Now why is it a lj80/81 well part of that was a my bad as I didn't realize the LJ81 was the lwb (2200mm) frame an I ended up making the swb (1930mm) frame but I stuck to the swb frame.
Specs are as below
Motor: Castle Creation 1900kv 540
ESC: Castles Creation mamba micro X
Transmission: Custom printed design with near 4:1 ratio (had a hard time making sure my center drives cleared the transmission and fit under the floorboard)
Axles: LosiMRC or ecx temper/barrage shortened till at the knuckle face is aprox 111mm wide! With custom designed axle housings
Servo: Savox 1257tg
Shocks: RC4WD 40mm micro scale shocks
Battery 2x 1cell turnigy graphene 950mah 65c (running in series)
Front suspension: 3 link with panhard (8 degree caster 8 degree kpi)
Rear suspension: 4 link
Wheelbase: 193mm
Track width: 121mm aprox
Top speed: 20mph
So with all that out of the way here are a mess of pictures!
Yes that is in tinkercad an yes It takes forever to load XD
Chassis, transmission an axles shown ready to be mounted to eachother the old tamiya silver can is there to make sure I left enough room between the servo an motor for the panhard
My RC4WD 1.55 an baja MTZ mounted up on the chassis
The center section of the cab being printed on my Cetus 3D printer (really consistent machine this print was 33hours!)
Here is the cab mount on the chassis (chassis has almost exact same body mounts as the real thing body has little donut/plate style mounts to screw to the frame)
Printed out front fenders and grill section an glued to the cabin (each fender has the inner an outer parts as one piece)
And hood just resting
Finally got my proper engine in!
Got the rear flat bed printed
I ended up printing a second cab trying different print settings but I ended up back at the blue cab after figuring out I could flip my shock mounts on the axles to get the needed wheel clearance for the fenders.
Hinges!
Rear boxes for the batteries and esc to hide under the truck bed
Back to blue with a seat and testing some custom light lenses and buckets for fitmet
I wonder what this is for....
Gotta hide the receiver somewhere!
Dash temp glue'd in
Open shot
Bumper installed
And I really think traxxas needs to work on their scale.... I know this truck is smaller then a chevy love but come on!
Specs are as below
Servo: Savox 1257tg
Wheelbase: 193mm
Top speed: 20mph
Hinges!
Dash temp glue'd in
Open shot
Bumper installed
