losi mini crawler shafts too short
bquin
Glendale Az
finished my DNA chassis with some of my own stuff......really good stuff, but now my driveshafts are way too short. Any ideas on something longer with 4.4 mm shaft joints?
if you use lower/upper links even after market ones that are for the stock mini chassis you will push the wheel base to something akin to 9inches. If your going to compete with this chassis you will need to shorten the links. If not then there are more than one way to lengthen drive shafts. You can buy anothe set and cut the male section off and the female section off then using the female section as a collar glue the male into the female to extend the drive shaft I know that sounds nuts but there are tons of threads to tell you how to do it.
As far as just buying something I don't think it exhists, besides all the aftermarket shafts out there I've seeen so far come along with a lot of complaints from owners.
