M3 screw assortment?
There's a place close to me called Maryland Metrics, they only deal in metric hardware. Their website is a bit confusing ( at least to me) but the customer service is great, maybe it's worth a call to them to find what you want.
Screw Loose is great! Awesome guy and good hardware! I like KNK as well.
Just AVOID RC Screwz whenever possible. I've had hardware come with the wrong lengths and he told me to cut them. That owner is a smart ass dick so don't expect good customer service.
I usually buy all my screws in bulk individually from McMaster Carr, but id like to go a different route this time.
looking for a M3 screw and nut assortment kit:
black steel (not stainless)
id like standard and nylon nuts
screws starting around 8mm and up to say 25 or 30 length
mostly socket head caps, but wouldn't mind button and countersink heads too
id like a nice organized labeled box as well. labeling wouldn't be a must I guess.
any suggestions?
I ordered two 650 piece button head Screw Loose M3 kits and they arrived last night; one kit stainless and one kit black oxide. Everything is unbagged and put away in my existing hardware organizer. This is my impression and answers to your questions.
The stainless kit did not come with M3x6mm, but the black oxide kit did. Conversely, black oxide did not come with M3x25mm (IIRC), but stainless did. Point is: if you need a certain size in a specific kit, double check that it is included and do not assume stainless and black oxide have the same sizes.
Every group of same size hardware had its own bag and each bag had an attractive little label. This label pealed easily and could be reapplied to the hardware organizer without losing any adhesive. While these labels were a small perk and did not factor into my original purchase decision, my hardware organizer looks freaking cool with each bin labeled. I kinda wish I had done this sooner or at least purchased a label kit, if they exist.
Both kits came with nylon lock nuts in silver coating. I was fine with this since I had just purchased 100 standard M3 nuts from McMaster for cheap. However, if you are trying to minimize an extraneous McMaster order, you may want to contact Screws Loose first and see if they can build you a custom kit that includes both nut types. Both kits also came with M3 washers that happen to be a usable diameter and not too think.
All in all, I am genuinely satisfied with my purchase from Screws Loose and will order from them again when the need arises. I do recommend them.
i got the rc screwz set this time and there is no way everything for a wraith is in this jumbled little box.
The RC Screwz kit I bought was organized enough that I wasted an hour removing and sorting out the different length hex head screws to get the right ones for the shock to axle mounts...
I use boltdepot.com, everything you get comes in an individual bag that has the size and how many is in it. Their bulk deals are alot better than mcmaster
