EeePee said:Try programming the start up with a different setting yet?
every combo available on the mamba...............it always acts just the same....Im thinking the Mamba is the bad part.
rockwerks said:I guess I can try and build a 8.4V 2/3A pack and see if the extra punch will help:roll:
TLTRyan said:If my mamba ever gets back from castle i will try my stock losi mini-t pack. It should be of lesser quality but the same voltage as your intellect packs.
Do your packs have a good charge in them? Once my GP1100 pack starts getting low it has the same problem as you.
If you built the pack yourself you may try checking all of your sauder connections.
johnrobholmes said:As long as the pack has decent contruction, the packs should not be the culprit. I hesitate to say the mamba is bad. When they dont work properly, they usually dont work at all. If it aint the motor though, and it isnt the battery, the esc is the last one standing.
johnrobholmes said:IB 2/3 a cells will hold 30 amps continuous draw, and burst a bit more. Go ahead and build the pack though, it wont hurt anything to try something else.
johnrobholmes said:in all honesty I dont really know! I have never found specs, and have not had the chance to throw a multi meter at one. All I know is that the motor works in our applications.
From the size and wind of the motor, I would guess that it can take around 20 - 25 amps continuous and burst 40 amps for 10 seconds. I will check out the average amp draw asap.
johnrobholmes said:Probably, it is a short can. But the diameter is 28mm. Like I said, I dont really know!
already got the mamba sitting here....Cole82 said:Should have got the Quark and revolver in the first place.8)
LMAO:lol:johnrobholmes said:sir yes sir.
Cole82 said:I tried the mamba too because it is laying around. Night and day differance when you can actually use throttle control. Like on the quark.
