Here is my first mock up:
Full droop:
You can see the left side is the Slash Powerstroke, right is the Powerstroke XT. Even though the slash powerstroke is disconnected, both arms droop about the same. Check. Xt making full use of the available travel.
Full squish:
My current mockup spacers, ID 1/4”x OD 5/16”x3/4” long:
Extended eye to eye length:
So a 3/4” spacer will get you the full available travel of a Powerstroke XT in the front.
Also, here is a comparison of the full droop front and rear, almost exactly the same:
My only real issue is that my local hardware store doesnt carry long enough M3 screws, 30mm is as long as i could find. The front two screws are not even threaded in and rears just barely. You really need 35mm and 40mm long screws to get the same thread engagement as the stock setup.
The aluminum spacers are not ideal because they are quite a bit larger than the M3 screw, however, they fit perfectly over the little locating nubs that fit into the shock tower on the front. I did order a 3/4"(19mm) thick delrin slab so I could make some rectangular spacers that should provide more stability and have the correct size holes drilled to keep the screws all lined up.
I feel this mod is probably the best you will ever get from a losi in terms of all around suspension performance and should dramatically increase tuneability. You can run a huge amount of droop for bashing, or you could lift it up to get some clearance for crawling, all while getting huge front and rear travel.
Now I just need to drop another $54 on my second set of powerstroke XT's.
