MAXXMASHER
Yeah, since I did this build so quickly, I pretty much just used what I had on hand to get this thing running. I really didn't think at the beginning I'd be able to build it in time for the trip to my Bro's this weekend. I'm sure after the first run, we'll be tweaking and changing things around. In fact, I already did a bit of adjusting this morning. The shocks were at a slight angle and they weren't moving freely enough. I solved that by mounting the bottom of the shocks outside the axle mount with longer screws. I also cut small notches in the frame where the two servos sit. The notches are a bit rough, but I'll smooth them out before I paint everything. I noticed too, that the upper links from the middle axle were not really moving freely as they should be. I used longer screws and a spacer between the frame and the ball ends, and now the axles articulate a lot better. Now it kind of looks like a worm going over obstacles. The big thing too, will be to see how it stands up to some outdoor abuse. I also need a screw kit from Harley. Some of the screws I'm using are a bit too long, while others are just long enough to get a nut on. Like I said, I'm just happy that it runs for now. I just put the hammer down and built like a maniac! My two workbenches look like a toolbox got turned upside down on them. Parts, tools, hardware, and metal shavings everywhere.....funny though, I forget to take out the trash, but I can find a stash of four locknuts I took off a truck and put in a box three years ago.....
FLM BL E-MAXX ~ BL E-4TEC Drifter ~ Pro-Trac Slash ~ SCX-10 ~ Wraith ~Custom 6WD Crawler~ 3 Losi micro scalers
