Menifee-Temecula area crawlers
Or you could just have the apple and go o he gym:lmao:
:lmao::lmao::lmao::lmao:You Make Funny:flipoff:
Just why would I go to a Gym? To get healthy? Not!
I rather look forward to the peaceful time of death.
The sooner The Better
Hey Nemo u figure out what happened to your 35 t motor.
Yep, It Broke:lmao:
Blew the dirt out got it to spin but has a tight spot in it, Gonna give it to Ickabob to play with.
Put an Axial 55T in for now, Thought I gave it to my Godson but it looks like he got my good Novak 56T.:cry:
Did find out something tho in the rooster crawler instructions. Need to ad 2 Capacitors. I noticed that these are on the Novak 56T but not the Intergy.
Instructions from Novak.
1. INSTALL MOTOR CAPACITORS
Electric motors generate RF noise that causes interference. The included
0.1μF (50V) non-polarized, ceramic capacitors must be used on all motors
to reduce motor noise & prevent ESC damage. Novak’s Crawler Brushed
Motors (#3545 & #3555) have the required capacitor’s factory installed.
Note: Some motors come with capacitors built-in. If your motor only
has two capacitors, you need to install a capacitor between the positive
& negative motor tabs––If you experience radio interference when using
only built-in capacitors, install external ones.
Solder 0.1μF (50V) capacitors between:
• POSITIVE (+) motor tab & NEGATIVE (–) motor tab.
• POSITIVE (+) motor tab & GROUND tab*.
• NEGATIVE (–) motor tab & GROUND tab*.
*If motor has no ground tab (below), solder the capacitors to motor can.
Negative (-) motor tab
**NO SCHOTTKY DIODE**
0.1μF Capacitors
Positive (+) motor tab
Ground / motor can
Extra 0.1μF capacitors are available in Novak kit #5620.
2. DO NOT USE SCHOTTKY DIODES
Schottky diodes must NOT be used with reversible ESCs (including
brushless). Schottky diode usage will damage the ESC & void warranty
Note; Ran the Axial 55T with thee Rooster Crawler, 5 minutes of run time it started to do the same thing as the Intergy 35T. Loss of power and friggin HOT!
Just Gonna get rid of yhe Rooster Crawler for good this time.
That's a good start, tekin is the way to go but you know that and our hats are off to you for trying that rooster crap. I think team cheese puffs like roosters.
The main reason I like the Roosters is because I got the first one in a trade and the second one was cheap. To be honest If I ever got my hands on a really good setup I probably wouldn't know what to do with it. When it comes time for me to buy one I will. I'm still leery about making that leap watching some of the guys have issues burning up esc's, crawlers & what not. The way I see it, if I had a great set up I'd be all worried about it all the time, then I'd have to but a Spektrum with telemetry so I could keep track of the temp and everything where would it end? Besides, stomping on the Taco Cheater would be to easy then. What fun would that be?
By the way, IT'S TEAM CHEETO NOT CHEESE PUFF!!:flipoff:
Yea the cheeto rig also has a rooster esc and he has been having some overheating on his motor. Could be an issue with that esc.
You could be right about that. Last time out it actually did allright. I thought it was getting hot but when I checked it it was O.K. The motor may be messed up from when it was getting hot or a piece of junk. probably a little of both.
Dang hopper, looks like I got hacked or something, you know I would never say anything bad about your rigs, heck next to mine yours are the next best thing out there:) plus orange is kinda close to red:lmao:
Did Armistice get a hold of your password or something?
