MEUS ME-10B radio.
Saltrock
PNW
I just got my radio today. First impressions is it’s good. It’s pretty light but the wheel and trigger feel solid and the return springs are springy. The screen is sharp and easy to read. It’s currently still charging but I am going to get into the menu tomorrow but moving through the pages is fairly easy. So far it’s hella worth the price.
I’m looking forward to using it. I also got a couple of the four channel micro receivers and they are small. Looks like decent quality.
Well shoot, the micro receiver uses some tiny connectors that I don’t know about. I won’t be able to use it till I get some of the proper connectors.
The big huge ten channel works with the larger connectors so I at least get to use the radio. The ten channel receiver is the same footprint as my old four channel, it’s just a bit thicker.
Got my end points and d/r set and it’s about ready to go. I’ll test it out later when I’m not watching this show.
Hhhhhm, I found the proper connectors in the second micro receiver. I’ve got it bound and the steering works but I can’t get throttle to work. The motor doesn’t even beep. I put my old fly-sky receiver on it and boom steering and throttle. I don’t know if I am binding the reciever wrong or what but I am bummed, I really want to use my new radio.
The menu is easy to get used to and I don’t have to much problems navigating it.
Depending on the esc, try the calibration steps to set neutral, full throttle, and brake. Sometimes the esc won't arm if the throttle trim is off center.
Also verify your throatle epas are at 100%, or the dual rate is all the way up when you calibrate.
second, are you sure you have the ESC wire plugged in the correct way/wired correctly. etc.
Here is a good video from The Shop - Mini RC about the radio. The micro reciever connectors are three pin micro JST according to the video.
So the problem was that I had not re-set the throttle calibration in the Furicar app with the new radio. I’m sure that’s a fairly noob mistake but I’m stoked I found it. It drives great now but it had some weird issues driving with the Furicar bluetooth hooked up. Easy to take it out, you only need it for the initial tune.
