My first build 2007 chevy silverado
Dood that is awsome are those the flares from a dingo? Was looking for a set for my super duty body
Looks great. How do you like them shocks and what length are they and how long are your links? I have the same body on my scx10. If you want here is my thread. http://www.rccrawler.com/forum/axial-scx-10/477410-leesc10s-scx10-dingo-build.html
thanks bro the shocks are 104mm g made zeros and are a really nice shock from my experience with them and nice and soft as for my links i used the stock honcho size with a 2mm spacer on each end the front lower links are 98mm + 4mm and the rear are 106mm + 4mm then for the uppers i changed to a 4 link the front uppers i used 98mm without the spacers for steering purposes(you may want to order some clockable chubs) and the rear uppers i used 106mm +4mm then the honcho came with spare parts so i switched the rear driveshaft male end to the spare one that is a bit longer and put i think 6mm bolts inside both driveshafts to make them stronger"thumbsup"
Yes there dingo flares i heated them with a heat gun to shape them for the body
found some time to get the cage painted first i painted it black but changed it to red
Re: scx10 2007 silverado update
Do you have any trouble with the axels? I extended links on my scx10 with tundra body and lift kit and it didn't work good
what trouble were you having with the axels?
heres a couple new pics just mounted the cage
Silverado looks badass and you made those fenders look stock. I like how you have those axles clocked Im sure it probably eliminates driveshaft binding that youd have if you didnt do it. Those shocks.. i needa hurry up and get me a pair!
Thanks bro took a while but the truck is almost just right waiting for 11mm wheel wideners clockable chubs and lockouts from vanquish then gonna start on electronics
heres a look at the driveshaft angles
FRONT
REAR
If it's what you like, by all means. It is way to tall to be much fun besides monster truck-type driving. Far from being scale. To each his own
