jimbo jones
This will be my first sporty build it will be used to comp her in Australia.
Being my first build if you can give me some input that would be awesome.
It will be a slow build as I will be buying parts for it here and there as I can afford it
Parts list
Chassis
BWD Carbon Nightmare-S Sporty Chassis - With Links
Plaig Bearing kit
SS screw Kit
Suspension
Scx10 shocks Front and Rear
Losi mini t springs
Hulksta spring cups
Transmission
AX10 tranny
Hot Racing Super Duty Light Weight gears
SDI drive shafts
BWD Motor plate
Front Axle
TKO-10 Axle Case
XR10 universals
Locked Up RC FI Spool
Axial over drive bevel gear
Xtra Speed Stainless Steel Front Drive Shaft
Vanquish XR10 Chubs
Vanquish XR10 knuckles
Hulksta derlin Wide beef tubes
Hulksta Engineering TKO-10 smash plate
Home made steering links
Rear Axle
TKO-10 Axle Case
Ax10 plastic Lockouts
Xtra Speed Stainless Steel Rear Drive Shaft
Axial under drive bevel gear
Hulksta engineering TKO-10 Rear link mount
Electronics
Holmes Hobbies TorqueMaster BR Mini RTR
Holmes Hobbies Puller 500 13t
RCOMG D4-ST-BF30S - 438Oz/in High Speed, High Torque Servo
FlySky TX
Castle Creations BEC
Wheels / Tyres
2.2 Voodoo pins narrow cut
CI duel stage foams
Hulksta carbon fiber wheels
Vanquish SLW
Parts list
Chassis
Plaig Bearing kit
SS screw Kit
Suspension
Losi mini t springs
Hulksta spring cups
Transmission
AX10 tranny
SDI drive shafts
BWD Motor plate
Front Axle
TKO-10 Axle Case
XR10 universals
Vanquish XR10 Chubs
Rear Axle
TKO-10 Axle Case
Electronics
FlySky TX
Wheels / Tyres
CI duel stage foams
Vanquish SLW
