new2rocks
BowHouse RC is pleased to announce our latest creation, the NC60 axle. The NC60 offers Wraith steering angles on an SCX10-width axle
Features:
-- Accepts Wraith short-side universals on both sides
-- Accepts Wraith chubs, knuckles & lockouts
-- Clockable chubs
-- Removable diff cover with integrated bearing caps for easy servicing
-- Available BowHouse RC lower link/shock mounts in multiple configurations
-- Accepts Wraith-compatible diff covers and bearing caps for more bling
-- Uses dual oversized (5x13x4mm) pinion bearings for added strength
-- Compatible with Wraith lower link/shock mounts
-- Choose panhard bracket with integrated shock and lower link mounts for chassis-mounted servo setups or servo truss for axle-mounted setups
-- Strong SLS nylon can withstand tons of abuse
You will need to supply front & rear axle internals, bearings, knuckles, chubs, lockouts, and hardware. If you are converting an existing pair of axles, you will be able to reuse the ring/pinion gears, lockers, rear axle shafts, diff and inner knuckle bearings (10x15x4), inner knuckle bearings (5x11x4), and bearings at the ends of the axle tubes (5x11x4). You will also need 4 oversize pinion bearings (5x13x4). Please see the next post in this thread for a complete list of components and parts that you will need to complete your axles.
Upon request, we can provide built-to-order sets of NC60s with pricing TBD based on specific components your request. Please email us at bowhouserc@gmail.com for more information about built-to-order axles.
For more NC60 information and pricing, and to order yours today, visit the BowHouse RC store on Shapeways:
https://www.shapeways.com/designer/bowhouserc/creations
Features:
-- Clockable chubs
