Just purchased and unboxed a new Everest Gen7 Pro. Noticed some issues right away.
1) There was a screw (85846) missing from the roof rack.
2) There was a "nick" in the antenna insulation on the receiver wire exposing the antenna wire. Not a big deal as I was switching to a Spektrum receiver to be able to use my DX4C transmitter anyway.
3) The screws (85837) holding the servo mounting plate (13814) to the chassis plate (13806) were loose.
4) The screws (85845) holding the steering servo (HX-15CS) to the servo mount (13814) were loose.
5) Two (2) of the wheel mounting nuts (70129) were loose.
6) One (1) of the bearings (02139) was missing from one (1) of the steering knuckles (18004).
Not major issues for me and everything is fixed and ready to run now. Be interested to hear if anyone else has seen any quality control issues such as these. Have to say though, I'm wondering whether I should do a complete teardown just in case there are hidden issues to resolve.
As others have mentioned, I am not impressed with the front wheel turning angle. Takes 25 feet to make a turn with this thing. It seems a waste to have CVA front axles and not make use of the wide steering angle available with this type of axle. My quick fix was to grind off the stops on the steering knuckles til I decide what might be a better permanent fix (that's how I found the missing knuckle bearing). Had to install wider hexes in the front so the tires don't rub the shocks at full lock. Went with 10mm I had on hand but probably 8mm wide would work. Stock hexes are 5mm wide and the extra 10mm of front track width is hardly noticeable. Probably have a steering angle equivalent to a stock SCX10 now.
I like most everything else except the cheap "scale" accessories for the roof rack. But, not a big deal considering the price point of this RC.
Will be a few days before I have a chance to trail this thing so I guess I'll find out then how it performs.
EDIT - have 2 runs in now. First run went pretty well but quickly identified an issue with front tire rub on body and bumper during full turn and suspension collapsed. Shortened links about 1/8" to see if this would help. Also slightly trimmed the body and bumper. Second run was today and still front tire rub at full turn, although not as bad. Thinking of taking another 1/16" off the links and maybe relocating the shocks to create more space between the tire and body. This would change the COG and maybe not look too good. See how it goes.
