Yeah, but that's assuming everything else that comes on the SMT is true 1/10 scale. Is the SMT's chassis a legit 1/10 scale, or did Axial slap the '1/10' on there to compete in the market?
I'm not here to say if it is or isn't true to scale as they claim, but I just wanted to clear up that the JConcepts wheels and tires are true to scale 8);-)
Quote from Axial description for the SMT - "Very similar to modern era full size monster trucks, this chassis was developed for maximum strength and an extremely detailed appearance. Not to mention,
it’s the first true-to-scale 4WD straight axle Monster Jam Truck available on the market today!"
Now back to topic, how much do the JConcepts wheels weigh? I'm assuming they are hex drive.
I'm working getting a weight, in the meantime, here are some Q/A FAQ's
JConcepts - Monster Truck FAQ -
Click Here for Video
Scheduled for a early/mid October release "thumbsup"
Tires and wheel -
1. What size are the tires?
The Renegade is based on the low-profile race tires already on the market. Actual size is 5.80"H X 4.05"W
The Firestorm is based on the 66x42x25 Firestone tires from Bigfoot. They are lowered cleat and detailed to resemble the actual scale tire. Actual size is 6.20"H X 4.05"W
2. What size are the wheels?
The Tribute wheels are based on a 90's style Bigfoot wheel in style and design. They are 2.6" bead mounting diameter and 3.6" wide. Scale MT wheels are 25/26" diameter and 36" wide.
3. Can you change the offset of the wheels?
Yes. We have designed 3 hub widths ranging from "stock clod" to extra wide. We mark them as 11, 18 and 25mm offsets to fit the various trucks on the market including the SMT10.
4. What wheel colors will be available?
3 color choices will be offered. White, Black and Silver.
5. Are there open and closed planetary caps for scale looks?
Yes. One of the caps is solid faced and must be removed to access the wheel nuts. The other has a hole built into it so the wheel nut can be accessed all the time. All caps and hubs will be the color of the wheel choice. White is of course dyeable.
6. Will the JConcepts tires mount on other wheels?
Yes. The tires can be mounted on any current Clod Buster or TXT wheel. However, they are sized to fit the scale sized JConcepts Tribute wheel.
7. What vehicles will the new Tribute wheel fit?
So far we have tested and approved them on the Tamiya Clod Buster, Axial SMT10, Axial axle based trucks and Traxxas Stampede 4x4.
8. What compounds will be offered in the tires?
We will offer two compounds of each. 1 will be our Super Soft Green compound and the other will be a Soft clay compound.
9. Will the tires include inserts?
Yes, both tires will include an open cell insert that is sized appropriately to each size carcass.
10. What items will come with the Tribute wheels?
Two wheels per package which include the offset hubs, closed and open planetary covers and hardware for assembly.
