Introducing our New Company as a primarily Redcat RS10 based supplier of aftermarket parts and accessories.
As promised some new products available for the RS10. As we ramp up there will be more products available and more information on the web site. We look forward to your feedback and suggestions.
All of our parts are machined and made from cast acrylic. We found it to be harder than delron so it doesn't gouge when sliding over obstacles. Besides it looks Awesome Clear!!
Skid Plate/Battery Tray Stage 1 $15
Skid Plate/Battery Tray Stage 2 $18
(Recommended over Stage 1)
Narrow Chassis Kit Stage 1 $25
(Recomended for strength compared to factory)
Wing Eliminator Kit $22.50
Rear Steer Lockout $5
(We had to stay with the clear theme ;-))
- Includes 1 Skid Plate/Battery Tray
- Channeled to fit most 6-7 cell stick batterys or 2S Lipos
- Utilizes Factory 2.5mm screws
- Same as Stage 1 kit but includes 3mm Stainless hardware and new (4) new 3mm plastic rod ends.
- This kit is recomended over the Stage 1 kit since the factory 2.5mm screws are weak and bend easily.
- Includes 1 Component Tray, 1 Narrow Skid Plate/Battery Tray, and 1 Nylon battery hold down bolt.
- Narrowed to 55mm to keep the amount of chassis near the ground as small as possible.
- Can use Velcro Strap, Adhesive Velcro or the bolt supplied to hold down the battery of your choice.
- Utilizes factory hardware and is capable of running the factory bat wing if desired (not recommended)
Stage 2 Narrow Chassis Kit $30
- Same as Stage 1 Kit
- Also Includes (4) 3mm Rod Ends and 3mm Stainless Hardware
- Includes (2) Acrylic Blocks, 8 3mm rod ends and stainless hardware
- Utilizes Factory upper steel links
- 2 position tunable adjustment
- Includes (2) pieces of 3mm Allthread and (2) 3mm nuts
Clear Plastic Beadlock Wheels $40
- Includes (4) Beadlock wheels
