I really need OTA steering on my rig, can you guys give me an estimate on when that product will be available and how much it will cost. thank you
Im running stock steering right now. I tried to put the linkage behind the axle but with axel mounted shocks and bent links it didnt happen. I plan to get the ckrc high steer knuckles but I want to wait to see the OTA steering kit first. I'm also running a 6cell 7.2 saddle pack battery which I am currently makeing some 3cell fixtures to put 3 of the cells on the front axel and 3 of the cells on the back axle between the gear mesh houseing and the wheel (on the side of the axel wear the servo is not located). I'm doing this to try it out and see if it will lower the weight and I'm also thinking of running the new beetlejuice chassis . I figure the cells and fixtures will get in the way of a OTA steer, so I'll probably go lipo soon. Once I finish the fixtures I will make a thread and post pics.
Having a milling machine at your desposal is awesome.
I heard that there might be some updates to the big boy kit. For instance a pre-drilled pinion gear that will fit a 540 motor, or some other housing reinforcement. I was wanting to check in on that as I plan to order the kit soon but wanted to check if there might be any updates before I purchase. Thanks.
Introducing our New Company as a primarily Redcat RS10 based supplier of aftermarket parts and accessories.
As promised some new products available for the RS10. As we ramp up there will be more products available and more information on the web site. We look forward to your feedback and suggestions.
All of our parts are machined and made from cast acrylic. We found it to be harder than delron so it doesn't gouge when sliding over obstacles. Besides it looks Awesome Clear!!
Skid Plate/Battery Tray Stage 1 $15
- Includes 1 Skid Plate/Battery Tray
- Channeled to fit most 6-7 cell stick batterys or 2S Lipos
- Utilizes Factory 2.5mm screws
Skid Plate/Battery Tray Stage 2 $18
(Recommended over Stage 1)
- Same as Stage 1 kit but includes 3mm Stainless hardware and new (4) new 3mm plastic rod ends.
- This kit is recomended over the Stage 1 kit since the factory 2.5mm screws are weak and bend easily.
Narrow Chassis Kit Stage 1 $25
- Includes 1 Component Tray, 1 Narrow Skid Plate/Battery Tray, and 1 Nylon battery hold down bolt.
- Narrowed to 55mm to keep the amount of chassis near the ground as small as possible.
- Can use Velcro Strap, Adhesive Velcro or the bolt supplied to hold down the battery of your choice.
- Utilizes factory hardware and is capable of running the factory bat wing if desired (not recommended)
Stage 2 Narrow Chassis Kit $30
(Recomended for strength compared to factory)
- Same as Stage 1 Kit
- Also Includes (4) 3mm Rod Ends and 3mm Stainless Hardware
Wing Eliminator Kit $22.50
Includes (2) Acrylic Blocks, 8 3mm rod ends and stainless hardware Utilizes Factory upper steel links 2 position tunable adjustment
Rear Steer Lockout $5
Includes (2) pieces of 3mm Allthread and (2) 3mm nuts
Clear Plastic Beadlock Wheels $40
(We had to stay with the clear theme ;-))
Includes (4) Beadlock wheels
Products Coming Very Soon:
Heavy Duty Servo Mount OTA Steering Bent Links Stainless socket head screw kitOur Website is up and running but lacking payment methods and pictures so in the meantime PM me or call us using the information on the WebSite
if you want to order.
ZNO-RC.com
What about a offering a combo kit with the big boy kit, steel differentials gears, hardened steel pin, aluminum axles, steel pinion with 1/8" center hole to fit the 540's. It seems that if someones going to purchase the big boy kit and put 540's their going to have to upgrade all the drivetrain to hardened steel/aluminum/etc because it will just brake due to the additional torque. Also look into offering a set of links that can fit with the stock chassis that can mount to the axles and clear the 540's. That would be awesome. A kit that includes all of that fulfill all redcat owners dreams.
wheels any of them come ie 23m.m spinedal?
