hobbypartz
The new Mad Gear RC Rock Crawler is the RTR kit to have for Beetle style that you always wanted, with big bore oiled fill aluminum shock, durable rock crawler tire and body chasis are just a few of the items that sets this RTR kit apart.
The stiffness: realistic looking frame and strong braces improves chassis rigidity
Tapered frame: for increased articulation and added realism
Simplified design: for easy and quick maintenance and assembly
Contoured skid plate: significantly reduces hang-ups on terrain
Proven durability: The axles have been designed with many features that are not available from other products on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration when designing these axles. The result is a far superior axle that will stand-up to some severe punishment.
Oil filled shocks: allow you to tune dampening rate, realistic coil over shock reservoir
Realistic looking 2 spring oil filled shocks allow you to control the spring rate and dampening to suit any driving style or weight of truck
Grey anodized aluminum links add to the scale realism
All new 5.0” wheels and sticky tires not only look realistic but are a huge upgrade in performance
Beetle Retro Style Truck Body included (Yellow/Green/Red/Blue)
Feature:
Motor Type Electric Brushed 70T High Torque Motor
Drive System 4 Wheel Drive
Length 447mm (17.59 inches)
Width 280mm (11.02 inches)
Height 150mm (5.90 inches)
Wheelbase 310-350mm F/R
Tires Size 130*55mm
Ground Clearance 70mm (2.75 inches)
Chassis Type 3.0mm 6061 Aluminum
Shocks Oil filled Big Bore Shocks
Speed Control 1/10 brushed ESC
Battery 7.2V 1800Mah Ni-mh Battery W/ Charger
Radio System 2CH 2.4GHz Remote & Receiver
:lmao::x
