New To Forum
xMOWERYx
Twain
Hello, Just thought I'd introduce myself. I've just started this new "hobby" which has turned more into an obsession. I never would have dreamed it would this much fun to work on something as it is to actually play.
I have an Axial Wraith (which may be in some ways why I work on it so much). I do have fun fixing it though. I bought it second hand with a bunch of extras for 180. I have already sunk about that much into it again with parts ect.
I just stripped out it's first steering servo and I'm in the market on getting something that will actually withstand these tires. something 3000 ounces of torque and up. But as I said, I am still new to this so, in the aspects of actually wiring stuff that is not stock, I'm a little out of my league.
I have read that I'll just continue to strip the servo if I just keep buying stock replacements, so I was looking at the Hitec but got sticker shock. Are they worth it? Also what is required to install one of those servos (extra wiring)?
It was pretty stock when i bought it. I've just been dressing it up with odd and ends. Integy lower links, new knuckles and hubs, bearings. Putting another motor in it as well. Just bought a stock one of those though.
Any thoughts or directions I should go with it?
Any of those mods you already did took way longer and more skill than changing out a servo. It's all plug and play. Just unplug the old servo from the receiver which I assume you still have in the stock receiver box and plug the new one in. You can run the wire the same way as stock. I usually only run Hitec servos but that's just me and you'll hear from plenty of people about other high quality options like Savox, Futaba, Holmes Hobbies, and others. I have a Hitec 7955 in my Wraith and with a BEC bumping the volts up it's pretty good. The stock Wraith servo is absolutely garbage. There's a spacer inside around the main shaft that just fails endlessly creating slop like crazy. Anyway, good luck with the build and welcome to the hobby...
Thanks for reply. That's the model hitec I was looking at as well. The Bec was just intimidating because I never wired it up before. And yes, stock receiver box. Is Castle Creations CC Bec 10A 6S Switching Regulator a good bec to use with the servo?
Yeah if you're not into soldering they HeyOK rig is pretty great. I didn't even think about if you were setup to solder. Honestly if you've never soldered before you should probably learn. It's really easy and the gear is cheap. It's a pretty useful skill in this hobby.
Love soldering, plus it looks like it's only two leads that will have to be done. I could honestly make a hobby of just soldering stuff together all day like a 3D printer lol. Not saying I'm that good at it, but I get the job done.
I ordered it. I'm gonna try just running the servo as is. Apparently it can work without bec. Just not as reliable. Since I don't do this competitively, it may work well enough for just putting around my area. I did order the bec also just in case I'm wrong.
Welcome to the forum and the hobby! I started into crawling and scaling with a Wraith, as did many of us. It's a great platform to learn on. Be sure to read Harley's Wraith guides stickied in the Wraith section here. They have a ton of useful information, a lot of which applies to other trucks, and all of which is very useful when you're getting started. "thumbsup"
Hitec are my favorite servos, great product with great customer support! HS-7955TG is minimum servo for Wraith, especially with metal steering linkage. I would go HS-7950TH, way better servo for not a lot more when you're already at about $100. CC BEC is way to go for either of these servos, soldering is fairly easy, watch some videos, read up, practice and always learning. :)
