Here, highlighted in orange, are the rules regarding tires allowed as per the official rules. Nothing said about the tires having to resemble a 1:1 :roll: You guys are grasping at straws now. I posted these rules in the other thread as well but here they are again.
I didn't make these up, pull them out of a hat, or anything else. These have been out quite some time. If an event is promoted as a scale event then there needs to be some rules to keep the vehicles in check. If you guys want it to be a free for all with the rigs the don't make it a "Scale" event.
I think it all boils down to guys running at GTG's alot but never actually competing. No other form of R/C lets you fudge the rules or try to interpret them to allow out of spec rigs.
Official Scale 4x4 R/C Competion Rules & Score Sheet
Official Scale 4x4 R/C Off-road competition rules and requirements.
The intent of these rules and requirements is to provide a standard set of guidelines for any scale competition held, official or unofficial.
1.9” Class
This class is modeled after typical street-legal off-road vehicles, non-trailered vehicles. These rules are set up to judge a scale truck as the "sum of its parts." The goal is to have trucks that resemble something you might actually see driving down a highway on the way to the trail. Understand the "spirit" of the rules and work within them.
> Chassis: The chassis or frame must be a ladder style and extend over the axles. Competition style RC rock crawling chassis are not allowed. This includes twin vertical plate designs (TVP), "stick" style, torsion and forced articulation. Tub style chassis are allowed.
> Wheels & Tires: Wheels are restricted to OEM 1.9” size. If the tires are cut down 2.2’s, they must fit onto a standard 1.9” rim and not exceed 4.25” in height and 1.75” in width. Flywheels brand wheels and tires and 1/18-scale Nylint brand wheels and tires will be allowed. 2.0's wheels are allowed as long as the tire attached is either a stock 1.9 tire or cut & shut tire that falls into the restrictions.
> Body: You must run a complete body, bumpers, fenders, doors and tailgates must be intact. Moderate fender trimming is allowed, but the basic shape of the fender must be retained. If no doors are run, the vehicle must have an interior (dash, floorpan, seats, etc). If no tailgate is used, the bed must be built out (drop bed). A shortened or lengthened body is allowed. A tubed bed must have a functional bed area capable of carrying a full-size spare laid flat, and tail lights(need not function), (rear fender and tailgate rules to not apply to tubed beds).
> Steering: 4-wheel steering is illegal.
> Drivetrain: A chassis mounted transmission and/or transfer case are allowed. Front or rear dig, cutting bakes, motor on axle (MOA) designs are illegal. Chassis with single or dual integrated motors are allowed, but the motors must always be powered (no electronic digs).
> Wheelbase and width: The dimensions of the vehicle are limited only by the body, but it must fit within the body’s fender wells.
> Comp-day modifications: The vehicle must be run as it was setup for tech inspection.
> Battery: The Battery must be placed on or within the chassis.
__________________________________________________ ________________________
2.2” Class
This class is modeled after typical off-road use vehicles, non-trailered vehicles and trailered vehicles. These rules are set up to judge a scale truck as the "sum of its parts." The goal is to have trucks that resemble something you might see driving on a trail. a purpose built off road vehicle (mud truck, hardcore trail truck, non competition rock crawler, ETC.) Understand the "spirit" of the rules and work within them.
> Wheels & Tires: Wheels are restricted to OEM 2.2” size. all OEM tires are legal, any modified tires may be no larger then 5.5"
> Body: You must run a body, fenders, doors and tailgates must be intact. Moderate fender trimming is allowed, but the basic shape of the fender must be retained. If no doors are run, the vehicle must have an interior (dash, floorpan, seats, etc). If no tailgate is used, the bed must be built out (drop bed). A shortened or lengthened body is allowed. A tubed bed must have a functional bed area capable of carrying a full-size spare, and tail lights(need not function), (rear fender and tailgate rules to not apply to tubed beds). All vehicles should be able to accommodate a minimum of a driver and passenger(no single seat buggys)
> Drivetrain: A chassis mounted transmission and/or transfer case are mandated. Front or rear dig, cutting bakes, motor on axle (MOA) designs are illegal. Chassis with single or dual integrated motors are allowed, but the motors must always be powered (no electronic digs). A switchable transfer case is allowed, but only between 4x4 and 2x4 (rear wheel drive).
> Wheelbase and width: The dimensions of the vehicle are limited only by the body, but it must fit within the body’s fender wells. Width is unrestricted.
>·No truck will be allowed with a RTI score over 500* measured from the bottom of the tire.
>“Tuber” vehicles will be addressed on site and maybe allowed to run in this class but no guarantee is given. All tubers must have at least a hood, grille, and side panels. Tubers should try to adhere to the spirit of "scale" and look as realistic as possible.
