No Brainer BEC
heyok
Vancouver, BC
If you have crawled for a while and noticed your steering is weaker than you think it should be, it might be due to the often weak BEC that is included in most electronic speed controls.
One fix for that is to run an external BEC. Sometimes you don't have the time or equipment needed to solder in an external BEC, so I am offering an external BEC that is really easy to install.
It is small and quite efficient as it uses a switch mode voltage regulator to step down the voltage.
** Note ** This is the No Brainer BEC in its current version. This one has the optional adjustable output for $30
The No Brainer 5Amp BEC:
To use it, the BEC gets plugged in between your receiver and steering servo. The battery connector gets plugged in between your battery and ESC. That's it!
Now the BEC that is built into the ESC only powers the receiver and the steering servo will get its power from the external BEC.
No need to remove the red wire from your ESC's receiver plug. The No Brainer BEC is a plug and play solution to adding an external BEC to power your steering servo. It comes preset to 6 (six) volts but I can set it to a different voltage if you ask me!
Your steering servo can work harder and your ESC can relax a little as it doesn't have to put up with the high current load from steering.
Did I mention that it doesn't cost a lot?
Part Number: NBRADJ
$30 plus shipping.
Now you can get a Dual Channel version of the No Brainer BEC!
Part Number: NBR2ADJ
$40 plus shipping.
NOTE: RC Truck Stop has a review of the No Brainer BEC.
You can check it out here.
It outputs 5.5 volts. Sorry, it isn't user programmable. Its voltage can be changed by messing with resistor values.
its a good idea but, it's pretty hard to compete with the proven CCBEC with it's programmability and around the same price.
good luck though "thumbsup"
The price is around the same as the CCBEC because that is what it takes to make something you can just grab and plug in.
To me, a guy running a comp crawler wouldn't want this. The No Brainer is more for the person that doesn't want to solder, but needs a quick solution to a rig that needs a BEC.
As soon as I get some time I will see about making a higher voltage version.
I've heard a vote for 6 volts. What other voltages would you guys like to see?
If 6 volts is what you want, I can do it! Same price. I will also consider other voltages if you request it at time of order.
Would anyone be interested in an adjustable version?
I can mount a potentiometer on there. Either a single or multi turn one. I kind of like having the whole thing covered up by heat shrink, but it should be possible to have a small hole in it for access to the control. You could cover that up with tape after or maybe a little silicone.
Hello,
great product "thumbsup"
7.4V would be just fine for the Hitec and other high torque servos which are
very often used in comp. crawlers.
Greetings Frank
Thanks for the input!
Again, I want to point out that in a comp crawler, you would probably want to solder in your BEC and not use my plug and play version. This is more for the guy that wants a quick fix to get their rig going again. That being said, I've been in a comp and had my CCBEC fail. I was just able to quickly plug in a No Brainer and was going again in just a minute!
yes,i would say 6v min.
could you do one for a dual steering setup?
say for a multi axle steup(6x6-8x8)..:mrgreen:
I'm really not sure about what you are asking. Do you mean that there are two steering servos and you want them both to run from the BEC?
i have 2 servos on my 8x8 running into a y harness at the moment..
and one sucks the power off the other one during a turn,and stalls the rec out..
what would be the best way to fix the problem?
2- becs?
You could run a No Brainer into that Y cable and it should be able to feed the two servos without any trouble. The wiring harness on the No Brainer doesn't feed power to the receiver but that's okay because the ESC's built in BEC should be able to handle that.
