noob? traxxas xl-5 an titan 12t i crawler king
bigbronco89
canada
any problems with the gears in the trans or front end and rear end holding up or will i be breaking stuff stock crawler king .i have a stampede i wanna take the stuff out of it xl5 an titan 12t.. thanks for anyhelp
I would look up the slipper mod by Skullking and do that before running that combo because you will end up snapping axles and eventually the gears in the tranny. I'd link it but I'm not sure how I think its either on the second or third page of the WK thread. Just search for sexy easy slipper mod by skullking.
AHH i wouldnt of thought of a slipper i will check that out thanks alot dude"thumbsup"
No problem, its not hard to change axles but its a pain the arse and that slipper mod really works.
"thumbsup""thumbsup"on the XL-5 esc. Not thinking so much on the Titan 12T. Its a fast motor, and a 550. Its has a arnature that is 30% longer, than a 540. In the end, it produces a lot more torque. Im not to sure the WK drivetrain wold be able to survive the Titan, might just shred it. Check and make sure to see if a 550 will fit in the chassis. In addition, you would need to gear low. There is also the option of running the esc in training mode.
I ran it with a 12t from a strike for a while. It held up fine. I did the slipper mod after i broke my first axle, though.
Take out the locker in the front, it will help also. Usually breaks the axles in front first. It will actually drive better without the front locked up too.
Wife:evil: put a stop to the swap when she found out how much the brushless setup cost for the pede.. so looks like the xl5 and titan are staying in the pede
so im just gonna try the 27 turn satrun $13.00 motor in the crawler king and maybe take the front locker out... thanks for the help and good info tho everyone."thumbsup"
With the larger diameter of the 12t titan motor you will only be able to run large pinions due to clearance issues if your running the stock chassis/tranny setup. I tried stepping down to an 18t on the Novak 55 on my CK and had to file off some of the trans case to get it to fit. Tall geared pinions and the power of the titan will not make for a good crawler and will be hard on your drivetrain. I ran an xl5 in my CK I had set up as a waterproof (I basically treated it like a submarine) and it was a great esc, i plan to put it back on it when I finally put it back together. Just bought my nephew a WK and it has made me really want to put my CK back together.
