Onyx 235 Lipo charger
sixhundred71
Guam
I have the Onyx 235 for my lipo. This is my first lipo set up and i heard that you have to store charge your lipo when not in use for a while. though my charger only has one setting that I know of which is just charge setting. Is there other settings like slow charge or quick charge that I'm missing?
A quick read of the manual reveals that it's just like my 230, no storage charge program. If you enter a reduced number in for the milliamps, like the manual says to do, it'll still go to full charge, just at a lower amp setting (ie. taking a lot longer).
Your best course of action would be to start it up as you normally would, then you'll hafta sit and watch the screen as it toggles through it's charge information. When the output voltage reads 7.7vo (2S), or 11.55vo (3S), then press start to end the charge.
So do i have to use a certain charge setting when charging?
And do I need to store charge my battery?
I have all the settings right but my battery won't charge to the full MAH.3300 3s. It will complete the charge between 100 and 1000 MAH. Anyone know what's wrong with it.
