Finally got some RC time and took the Wendigo out for some blood. OK, maybe just to play on some rocks, but you know. It was a hot morning and I was way hungover from a wedding the previous night, so it was a short run but plenty of time to get the feel of this truck.
Before running...giving the rear driveshaft the stink-eye. Not a lot of engagement there. It held up fine (for the record) but keeping an eye on it.
Also moved the front shocks back 1 hole. They were raked slightly forward at the top, and I can't stand that. Now they had a slight rear rake at the top, and all is right with the universe.
My partners in crime were running a little late, so I went down around the creek just to play around a bit. First impressions: fairly stable, a bit overgeared, and the steering was going to give me hives.
...after 10 minutes, I noticed I was dragging a fishhook. Not good! Axles are tough, didn't hurt a thing.
My friends rolled up, so while they were getting set up, I moved the shocks to the uppermost holes to lower the truck a bit and cranked down a bit on the preload in the back.
That steering angle... good Lord, it's just terrible. It's rare that I have a truck that my CR01's will turn circles around, but boy this is it. Not a knock on Redcat in any way, this is marketed as a Rock Racer and real sharp steering would be barrel roll city. But if your considering this truck as a trail truck or crawler, be forwarned. Not to mention the servo seemed super weak, so my steering all day was vague at best.
Having said all that, it was time for some real work. With the motor up front and big 2.2's, it's pretty darn capable, even mostly stock. Got up some climbs my other trucks wouldn't even look at, and surprised me in a lot of spots.
This ledge is super steep - I don't have a 1/10 truck that will do it. I didn't expect this one to either, but it hopped right up there, making a total liar out of me.
Made short work of my usual test rock. The tires are pretty grippy, the new compound is pretty good but they suffer from the same characteristics as the 1'9's - hop. They tend to hop on high traction climbs, which breaks momentum. Noticed it quite a bit...I'm thinking some siping might make a difference, but for kit tires they are pretty good.
Wide stance makes for some interesting lines. Can straddle stuff I wouldn't normally try with my other rigs.
Was running with a pair of TRX4's that had enough brass between them to recast the Liberty Bell. Still, I had no trouble going where they did, and even showed them up in a few places. Not bad for out of the box performance.
It's a bit nose heavy...
Managed to stick the nose in quite a few spots. Maybe not ideal, but fun!
Brood motor was excellent. Handled the high gearing well and was super smooth. It and the ESC were definitely on the warm side, verging on hot. The gearing is an issue, not sure what I can do about it....it's drivable, but it needs to drop a few more teeth if possible.
All in all, very happy with round one. Only ran for about 2 hours before we called it a day, but this truck has a ton of potential. On the fix list: better steering, lower gearing, maybe a touch of brass down low. Mods to come.
