Our LNC 2.0 and LCC...
Tib
Harrisburg/York
I figured I'd post up a few pics...
I was into RC's back in the early 2000's, when Nitro and the Team Associated TC3 / NTC3 were the touring cars to have.
Got the bug again when we went to a local event, got the 3 year old a ECX Temper 1/18 and me a LNC 2.0...
Well once he mastered the ECX and I ran across and LCC roller, it was time for him to get a 1/10th.
Here is our toys;
LNC 2.0
4WS using the Losi LOSB2046 Kit
Spektrum S605 for both F/R Steering Servo's
Currently 3oz weight in front wheels, 2oz in rear
Relocated ESC to battery tray to run 4WS
LCC Lower Links
Losi Low Profile Carbon Fiber Front / Rear Servo Mounts
LCC Drag Links Front / Rear
So on to my new toy, the LCC.
I picked up the roller off a private sale on eBay. Barely had to clean it up, was barely ran.
Currently;
HobbyWing Quicrun 17.5T/1900KV Brushless Sensored with 16T Pinion.
HobbyWing 10BL60 Sensored ESC
Hot Racing Aluminum Motor Mount
Losi Low Profile Carbon Fiber Servo Mount
Spektrum SRS4210 Receiver
JX PDI-6225MG High Torqure Servo
Losi Aluminum Adjustable Rear Link Mount
Axle Grease Access Holes drilled with Set Screws
Future plans are to swap this Motor/ESC to the LNC 2.0 and upgrade to a Tekin/Holmes Hobbies.
Here you go.
You just have to drill a hole thru the axle case and fill it with a short screw or set screw. Just make sure that it's only long enough to go thru to plug the hole and not rub against anything.
All of them are up except for the grease mod picture. Thank you! Very nice looking rigs.
149 r/c worx team driver
How do you like the speed of the brushless? Is it 3 to 5 mph?
So far great. I have a TC3 that I run around the parking lot for fun with a Hobbywing Setup in it...I run it hard with tall gearing and don't have any problems so I figured I'd put one in the LCC for a short while until moving it to the LNC 2.0.
This setup is a 17.5T/1900KV Sensored...No issues so far on low speed and has more than enough top end/wheel speed. I'm using a 16T pinion. I don't plan on doing any comp's just enjoying time with the kid so it's plenty.
I picked up the Motor and ESC separately and spent about $85 total. I already had the programming card from the TC3's setup. I did change the programming, put the lipo cutoff at 3.2, full punch throttle and full reverse.
I plan on going to a Tekin/Holmes Hobbies but I'll let me kid get used to the 1/10 before switching the motor/esc over.
Good information. I'm building jrs rig for comping but it will get wheeled for fun also
