Dual motors mean 2-motors, 2-ESC's & $$$
Depending on the "can" size a larger single motor would be plenty.
Tekin's 4030 - 40mm x 69mm & 4038 - 40mm x 77mm (length oversized for sensors) are in-runners & will have more power than the average person will ever need.
Motor size will determine quantity needed, my 2830 sized out-runner motors do well in a crawler, but I would never put them in a race setup without extensive testing.
The 3656 in-runner has no issues with racing trucks up to 7 pounds at race speeds for 10min.
The "monster setup" you are going for won't likely be 10 min of continuous pounding so a slightly undersized motor may not get hot enough to fry.
I build around the concept of 100% duty cycle with a motor temp of 140f or less as a target.
There are a lot of "tricks" to tweak setup if you know what you are doing.
-motor timing (adds heat & RPM)
-ESC timing (adds heat & RPM)
-Lower Gearing (reduces heat to a point, also reduces speed, & amp draw, but can increase ESC's temps due to switching speed)
-Higher Gearing (more apparent punch, higher amp draw, can create heat if overloaded)
Multi-pole motors are more sensitive to ESC timing but can really pep up a flat feeling motor.
In an unknown chassis/setup start in the middle & adjust gearing/timing as needed.
I have a 4pole 3656 2350kv in-runner I really like.
The next motors I want to test are 6pole in-runners They look like 3650 sized?
https://www.amazon.com/dp/B01G4TXUV...TF8&colid=1UX3A89X56ABP&coliid=I3HXQKV4774G22
