Phenom - Limited's 09 Comp MRC
Ok, so I have ran 2 packs through the rig since last night; about 2.5hrs. All I can say is wow! There is a night and day difference over the stock configuration. There was also a huge difference when I switched to the rear mini t shocks. I have relieved most of all the torque twist in this machine. Lastly if there are any issues with this crawler, it may still be in the weight distribution, which is an easy fix.
hey i tried that link setup on my mini ss with the fronts parallel and rears triangled and i like it a lot better.
I think limiting the shocks a little to lower the its cg and adding some foward bite are in order.
You sure know how to start a project!!!!! Build looks great....nice and clean! What kind of weight are you running in the rims?
looks freaken great how did you put the 2mm rod in?"thumbsup""thumbsup"
The 2mm rod (non-threaded cut to desired length) just slides right in and the tubing slides over and in between the link ends. Finally you cap off the outside with the supplied cap head screw.
