racin707
I've used rattle can bed liner, on a few of my things, seems to do just fine, sprayed on the out side of course
Sent from my XT907 using Tapatalk 2
well the portion i masked off on my beat up body came up when i pulled off the masking tape.
i wanted to try it with masking tape so i could see how it would react when i pulled it off. i wanted to do a design ,not just a simple color. maybe have to pull the masking tape up when the dip is still wet ? that in itself creates an issue as it takes more then one coat of paint....
I masked the lines on these:
And when I had enough coats on, I ran an exacto blade along the tape edge and slowly peeled up the masking tape. This is what makes the dip durable, it sticks to itself. These have held up since June, no problem. Once it's cured, the edge is durable, and won't start peeling unless you start to roll the edge.
If you check out the video here the guy shows how to use the masking tape and heavier coats to get that edge.
I'm probably going to use this for a modified wraith cage soon to keep the matte look, and easy to redo if I need to.
i maybe have to pull the masking tape up when the dip is still wet ?
When pulling the masking tape up, be sure to pull the tape back against itself. "thumbsup"
I know expermenting is part of the fun, but I have to ask....Why plasti-dip? I can see doing the "Line-x" look on a bed. I'm not by any means critisizing your idea, just curious as to "what" look your going for. :roll:
Be sure to post up some pics. "thumbsup"
