Plugging 4mm bullets into regular bullet connectors?
SStone
WNC
My stock Twin Hammers motor died this morning. Wasn't even running the rig.
Anyways...
I have a 35t rc4wd motor that works but it has 4MM Bullets while the Tazer ESC has regular bullet style connectors.
Can I plug the 4mm bullets into the regular bullets on the ESC and run it for a few packs without destroying anything? The motor is out of my daughters rig so it needs to stay how it is.
I searched.
And searched....
And searched....
Thanks.
You will be fine as long as the push fit is tight. I put a BRXL in my twin hammers and shoved the stock bullets into the 4mm bullet of the BRXL, works without a hitch.
That's how I have it on a couple rc's. I just take some pliers and flatten the regular bullet just a little bit to get a tight fit, then I shrink wrap it up. Make sure however to put the piece of shrink wrap on the wire before pressing them together.
Thanks for the information fellas. I figured it would have been fine but just want to make sure.
