Rock Dodger
Picture of ’46 Power Wagon front end (not mine)
This wheel and tire combo is the look I’m going for.
This is the RC equivalent.
RC4WD 1.9 Vintage Cruiser Stamped Steel wheels (beadlock, set of 4)
RC4WD DUKW 1.9 Military Offroad Tires
These wheels and tires are part of the project to put the Proline ’46 Dodge Power Wagon body on a RC4WD Trail Finder 2, LWB chassis. I’m going for original authenticity here, not trail performance.
About the wheels, according to this picture, there is a “steel” colored trim ring on the black wheel. My problem is how to recreate that. I don’t have the dexterity to simply free-hand it with a brush and masking it off with tape is impossible.
I got the idea that if I could find the right sized disk, I could use it like a template. Digging through my big can ‘o washers, I turned up just the right diameter washer. Encouraging yes, but how to fix it to the wheel?
These “vintage” wheels are not for want of complexity. Each one consists of 10 bolts, 5 nuts, 2 lug spacers, inner ring, center ring, outer ring, “hub cap” and axle nut.
The hub cap sticks out past the outer ring when assembled, so disassembly is required in order to place the washer/template flush on the outer ring. In order to get a paint resistant seal between the washer and wheel, I covered one side of the washer with electrical tape. This worked a treat.
Fortunately, every piece involved has a center hole. This is key to the key. Using a reasonable sized bolt with a wingnut made for easy fastening, holding the washer tight to the wheel – the key. I still needed a way to hold the assembly steady, so I fashioned a jig from a chunk of 2x4 with holes/cuts as a key hole. A band of tape around the outer edge of the rim and we’re ready to paint.
I’m fairly pleased with the result. It’s up to my modest skill level especially given that painting is my least favorite aspect of model building. Had fun making the jig though.
I've only begun painting the body and have very little idea how to fabricate the front bumper/winch and interior.
