proline cheyenne rims
shrek
commerce twp.
i was thinking on buying these rims, my question is how do you narrow them do you just cut the back bead off and slide it forward like a stampede rim or do you leave a little bit of material next to the bead and glue back on to the rim, your input will be very helpful,thanks gary.:)
Just remove the desired material, and glue the inner bead back on. I left about 3/16" on the inner bead side, and cut all the way to where the webbing starts on the outer bead side. Final wheel width ended up at 1 and 7/8". Hope that helps.
thanks, this is for the non beadlock wheel, i think i seen that you have beadlocks, is that right or no.:?:
