My new one that did not work, part # Z-E0024
Specs below.
I bought this new and it did NOT work, fan and servo, but no reverse. forward on and off again, jerky, no modulation. Then no motor movement, some noise a jerk and then nothing. It is supposed to be plug and play, ready to go. I agree it sounds like the receiver is not working with the ESC, but is has a BEC , switch and no set up button. I sent it back but wasted time and effort and shipping 2 ways for nothing more that a hassle.
THIS IS AN OUTCRY HIGH PERFORMANCE ENHANCED BRUSHLESS SYSTEM FROM RC4WD. Outcry Brushless ESC (Electronic Speed Controller) is created from the ground up. Cutting-edge circuitry and a powerful BEC (Battery Eliminator Circuit) at an amazing low price! Speed Controller Specs: Motor Limit: > 16T (3300kV) Sensorless Battery Limit: 4s LiPo or 5-16 cell NiMH Input Voltage: 6V-14.4V Weight: 79g / 2.78 oz Size: 44mm/1.73inch x 33mm/1.29inch x 26mm/1.02inch Advanced 6V/3A Turbo BEC Output: 80A Connectors: Futaba J, 4mm Bullet for Battery and Motor, Tamiya style for battery (all pre-installed) Status LEDs: 1 Delay in reverse: Yes Drag break: Yes Lipo Cutoff @ less than 70% 14 gauge wiring Fit regular pinion gears (3.1mm) Made for 6x6 Truck, Corr Truck, Crawler, Scale Truck, Touring Cars Warranty: 30 days Whats Included: 1x Outcry Blue Brushless Motor 1x Outcry ESC (Electronic Speed Controller) Special Notes: While this unit can handle 4s Lipo. A person with experience with 4s is best. When running on 4s Lipo you will want to constantly check the motor and ESC temperature. Not designed to run in Monster Truck or 1/8 buggy.
