pardonmyn00b
Any idea if there is an upcoming shaft to bridge the gap? ;-)
Get the longer one and cut it to length. Same price.
Just a warning to anyone that buys a longer set and plans on cutting them down, they are not splined the whole way only half way. Found out the hard way today:x Otherwise they are pretty sweet"thumbsup"
So does the Torx head act as the u-joint cap? Wondering if they can be worked loose due to rotation if they are.
Also any updates as far as durability? Kinda spendy for me to find out the hard way. Thanks.
Does anyone have any thoughts / experience with these vs the mega truck shafts ?
Thanks
x2, did this get answered??
Anyone have thoughts on it?
$29 versus $49. The Ultimates look fantastic, but is that workth $40 extra for a set?
I DONT RECOMMEND IT. I've gone through 2 of the mega truck drive shafts and the pins do not hold up. I'm running rc4wd 2 speed, cc mamba max pro esc, Tekin Redlin 17.5T burshless, GCM transfer case 1:1 gear set. I'm now currently using 65mm- 85mm JunFac shaft from motor to transfer case. The second set I got warranted by RC4WD also broke. I'm also running 3S Lipo 5000mah 30c. I broke mega shafts that was in the rear in 1st gear. I Just purchased the Ultra Scale Hardened Steel Driveshaft. I will be testing them out and hope they hold up, I'm actually running a Junfac carbon steel drive shaft in front I have not broke one.
Hope this helps.
I just lost a screw and the sleeve that went with it today..smh. really irritating lol. Anyone know where we can get the replacement torx screws and sleeve/bearing? I just emailed rc4wd today
Sent from my SGH-T999 using Tapatalk 2
That did not brick it gets held by the pin that goes through the pinion hole and out the other. Hope this helps.![]()
I forwarded this link to RC4WD hopefully they chime in to help your issue.
