Stavin Trucks
Just put in an order! Thx
are the brackets for these to go on the 8 degree VP setup still in the works or ?
Hate to be a stick-in-the-mud, but it should be made more clear that screws are not included. You know, something like "hey, you're gonna need 3mm screws for these". How about this, "Screws not included - get your SS screw assortment here"? Then you can sell them and gouge even more!!
Oh, I forgot - I can't even use my $70 weights since they don't fit the Axial "Rockster" wheels at all. I knew it would be tight going into the wheel, but I knew that I could at least run half weights on the "inside" of the knuckle, but - nope - you can't even run an empty holder on the knuckle with them. Since these wheels are by are the kit's manufacturer, you might think that a few people are running them, hmmmm?? You might want to alert your unsuspecting "marks" that these things only work with SLW-type hubs and wheels. There's even a post on this forum by william when asked specifically about the rockster wheel indicating that they'll work, but you "might not be able to load the wheel up". What should've been said is that they "don't work at all without modification" on the rockster wheels.
Oh, well. I supposed I was destined to get vanquish wheels and hubs anyway, which will push me to the $1500 mark - sweet!
Yea, I expect to get jumped on, but I don't believe that there's too much more that can be said. Well, except for, "you should've already known that". I did expect that they might not come with screws after watching Josh's video (part of his Poison Spider Budget Build series), and I didn't expect that I could fit a ton of weights inside the wheel without grinding it as per the post from the rc bro himself... But I did expect that the holder itself would fit inside the wheel so I could at least use some half weights until I get some "appropriate" wheels....:shock:
