RcBros Knuckle Weight System for VP XR10 and Wraith Knuckles
Hey just got some of your knuckle weights and noticed they are not all drilled the same??? in the pic the three weights on the left all have a threaded top hole and unthreaded lower. the weight on the right is the opposite..... is this normal?
Please help
Um..Flip that one over and it will be the same as the other 3.
Not exactly. the holes are drilled at different distances front the end of the weight and if you look the weight on the right is opposite the others on both ends
When I had them on my Wraith I found the reason they were made that way so they will stack easier.
Just don't understand.. I purchased two pair, one pair were drilled themsame the other pair opposite. I would understand if each pair were mixed???
As I mentioned in the pm, this is not normal. Now that I have a picture I'll get you a replacement out in the AM. "thumbsup"
Everyonce in awhile, these slip past me, I apologize.
If your running a Bully 2 Knuckle these holders are the ticket to solving all your front weight needs!
Each holder is slotted allowing the brass weights to be moved forward to back giving you multiple tuning options to fit your needs.
You are supplied with 1 left and 1 right per order.
Cost is $10.00
Available here: Bully 2 Knuckle Weight Holder | RcBros Hobbies[gallery]/0/
Want to pick up some knuckle weights but it appears the .25 full are out of stock, any idea when they will be available?
Ordered and received! These are great quality and designed well. Just for anyone looking to get these, I was able to fit one .125 half weight on the inside, one .25 full round, and one .125 full round on the outside of the knuckle using VP 350 SLW hubs on Proline faultline 2.2 wheels. If my math is correct, that's just over 2.5 ounces per side. Thanks RCBros for a great product and excellent customer service!
What do most people order for weights?
Really depends on the weight of the rig. The heavier the rig the more weight you will want to use.
Also goes for the traction in which you crawl on. The higher the traction, the more weight you will need.
I tend to ask our customers to order enough to max the vehicle out with wheel clearance and tune from there.
One pair of full .25 and full .125 with a pair of half .125 is a good start base.
I ordered a Evo chassis from Bruce. When it comes in I'll pm you and get list of all parts needed for the weight. Also thank you for the fast response and shipping of the shock cups .
I love these RCBros knuckle weight kits....I have two complete sets and just ordered two more for my other crawlers; highly recommended.
