rcracer78@gmail.com
Hello my fellow crawling junkies. This is my first post so please bare with me. So I just installed the brass Beef Tubes up the front on my RR10 Bomber, which installed flawlessly btw. However, once I installed the aluminum Beef Tubes in the rear, I’m left with 2-3mm of play in the axles....on both sides! Per Beef Tube instructions (and the only way to make them work), I had to file the flange on the diff-side of the axles, just enough to allow them to slip through the BTs. Here’s a little video of my issue:
http://www.dropbox.com/s/bacdnjk9aryhgyk/2B1DB8EE-4D0B-4F97-B018-78D9912C4033.finalVideo.mp4?dl=0
My rear setup consists of the following btw:
-Stock plastic AR60 housings
-Aluminum Beef Tubes
-VP axles
-Axial HD 43/13 bevel gears (HD 38/13 up front)
-VP spool locker
-VP clamped aluminum lockout
-VP aluminum truss (titanium upper & lower links too)
-Fast Eddy’s ball bearings throughout
-MIP drive shafts
(All metal-to-metal screws are snugged with blue Loctite)
As you can see, I’ve got a little inve$ted in my rear setup. I just really like my crawler to be as reliable and durable as possible. 2-3mm of play in the axles just seems like a weak link in the drivetrain. Any ideas to help out a fellow junkie would be greatly appreciated."thumbsup”
Thank you,
RCRACER78
-VP axles
-VP spool locker
-MIP drive shafts
Thank you,
RCRACER78
