Whirlybird
As you know space for electronics on a crawler is tight, so any extra room is nice. This is a guide to show you guys how to remove a useless on/off switch from your esc, in this case a Sidewinder. Doing so will make it easier to mount your esc because you have one less wire to mount. I would only reccomend doing this mod on an esc that does not use the on/off switch for programing.
Disclaimer: If you preform this mod you run the risk of voiding the manufacturers warenty. If done incorrectly it is also possible to harm your electronics.
The first step to remove your switch is to open up the ESC. The sidewinder is held colsed with a sticker. To open the ESC cut the sticker along the case seam.
Next cut the switch wire 1/2 inch from the ESC case.
Now strip both sides of the wire you cut and twist them together.
Solder the wire end in place.
Next put a small peice of heat shrink on the end of the wire so it does not short on anything in the case.
Lastly fold the peice of wire back into the case and close it up. The keep the case secure use a small peice of decal or clear tape.
Now your done the useless switch has been removed. If you would like to replace it later just resolder it back on.
