Robotboy
I wanted to build something "new to me" and missing a Wraith in the stable I
figured I'd give this a shot. Going for an all around fun rig, some speed and
some crawl-ability. Going to be a work in progress. Seeing what works and
what needs to be changed.
I picked up the 1.9 RTR, took a pic and did a total disassemble on it. Outta
the box...
Picked up an Element IFS kit and through it underneath. I did some research
and from what I could gather I thought it would fit. So happy when it did. :mrgreen:
Next up I wanted trailing arms in the rear. Went with the SSD Bomber ones
and used shorter rod ends. They're still a bit longer than I wanted but they'll
do for now.
Right now the wheelbase is sitting at 12.75". Eventually I'd like to get it to
at least 12.5.
Dropped in some MIP driveshafts and installed the IFS skidplate.
Electronics installed. CC 2850/Mamba Micro X ESC, SPT 25kg servo, RX
bypass and Hobbystar 6A BEC.
Going with RC4WD 1.9 MT Baja Pro X tires stretched on some Chanquish 2.2
beadlocks.
Mixed and matched some parts to come up with a rear sway bar. On the
fence about having one at all but thought I'd try it. After a small test run the
Wraith is better in higher speed turns but I think it's too stiff for anything
else. I'll have to come up with something with a little give. This one has
none.
More to come....
the box...
do for now.
at least 12.5.
beadlocks.
none.
More to come....
