Running LEDs from Rx
karajabola
Southeast MI
I understand this question may be hardware specific, but I will ask anyway. I'm curious what the full voltage range of the signal pin is on a receiver.
Is it 0 - 5V?
Is it 0 - Rx supply voltage (in other words, the ESC internal BEC voltage)?
Why am I asking? I'd like to do a poor mans light controller (i.e., no light controller) and hook my LED harness positive lead to the signal pin on my AUX channel instead of the positive pin. That way I can turn the whole LED harness on or off with my radio.
If that doesn't work, I suppose I could use a relay or transistor and use both the + and signal pins on the Rx, but I'm trying to keep it simple. :-)
Any thoughts? I will tear my setup open if I need to, but I thought I would ask first. The other followup question is if the current carrying capacity is the same on the signal pin as it is on the positive pin.
Thanks. I hope this is clear, hard not to be wordy!
(For reference I'm running a Sanwa/Airtronics RX-462 and a HH BRXL ESC which has a 6V internal BEC)
I don't believe just hooking up the lights straight to Rx works, regardless of pin, but I can't imagine the voltage output of the signal circuit is very high.
Sent from my XT1585 using Tapatalk
You can get receiver voltage from your receiver - what I mean by that is the voltage supplied by your ESC's built in BEC or your external BEC. Yes, you can take it from the Aux channel connector or any channel's connector. The usually red and black (sometimes red and brown) wires on a servo connector are the power connections. The remaining pin is the servo signal and often has a white (sometimes orange) wire going to it.
This might be helpful:
http://www.rccrawler.com/forum/electronics/422460-how-wire-leds.html
Rx voltage is whatever your esc bec voltage is, so in your case 6v. You can pull power from any open channel on rx, but you won't be able to turn on/off unless you have some type of light controller hooked up.
Mike, for leds to cause brown outs, you would have to run a sh-t ton of leds to do that. Meaning enough to pull a few amps and that's highly unlikely anyone would run that many.
Thanks for all the input everybody. There are a few suggestions I will need a light controller, however, no comments about the signal pin itself. I think I will investigate the signal pin before I commit to a controller. The goal here is that if the signal pin outputs an analog voltage between 0 and 5 or 6V, and it carries sufficient current, I could use it in place of the the positive wire.
Something tells me though I will find my plan is flawed. Perhaps the signal is not analogue, but instead PWM. I will post again if I find out anything useful.
With leds correct, add a winch or other do dads, then too much draw..... it's always the amperage not voltage
Hang up and Drive
Well, my plan is definitely flawed. The signal pin is not a simple analogue output. It's a PWM signal that, by my radio, varies between about 9% and 20% duty cycle at about 100Hz.
So, that explains why everyone uses a LED controller when they want to control their lights with their radio [emoji51]
So, now I'm in the market for a simple LED controller. Heyok, I read your thread you posted earlier and I am interested in your wares, do you have a site or thread somewhere I can look at? I'm looking to power a harness from my radio, I don't need braking/turning functions. Just on/off. Compact and waterproof would be awesome.
Do any others have LED controller recommendations? Thanks.
This light controller fits the requirements you listed:
http://www.rccrawler.com/forum/vendors-electronics/290418-remote-switch-led-lighting.html
This one is good if you have a three position channel:
http://www.rccrawler.com/forum/vend...-dual-rc-switch-led-lighting.html#post3014403
You can find all my parts here:
http://www.rccrawler.com/forum/vend...eyoks-rc-electronics-items-all-one-place.html
If there is something you would like, send me a PM, or you can look through my web store:
https://www.freewebstore.org/heyok-performance
Thanks,
Al
