VMGontheRocks
I picked up a wraith in parts a few months ago and assembled it. See build thread here: http://www.rccrawler.com/forum/axial-wraith/567883-scotts-wraith-build.html
It was fun to mess around with, but it's not something I could ever see myself driving. I traded for a full ToyZuki set up with the plans of building a wraith axled ToyZuki. But then things came up and the wraith sat on the shelf and the chassis on the workbench.
Finally got around to actually starting the build this past weekend.
Current state of the wraith before the tear down:
What happens when Jokerswild comes over and we work on toy trucks, they all end up on their sides:
:lmao:
Toyzuki set up waiting for wraith axles:
First order of business, front axle coming off:
Only part's I'll be using from the wraith:
I'll be converting the rear axle to unis, knuckles and c-hubs for 4WS, those parts are somewhere in a bag :lmao:
Since I'm using the Toyzuki forward motor mount, I'll be running a 3-link with panhard bar in the front. The wraith was running a 4-link, so I need to remove one link:
I'll be using a VP panhard bar mount on the axle:
Since I'm using wraith axles and the diff is on the drivers side left, I will be switching the motor over to the passenger side. As it currently sits:
Disassembled:
Flipping the motor plate:
Screws installed:
Back installed on the truck with the motor now on the passenger side:
Since the motor is being flipped, I'll also need to flip the skid and transfer case to the other side of the chassis. That means flipping the input shaft of the transfer case to the other side. How it was:
Input shaft flipped:
Installed on the skid, ready to go back on the chassis:
I'm using VP incision links, to get the right length for the lowers, I added Jato rod ends to one side of the links. I chose the skid side as I had the links already attached at the axle:
Started to get the front assembled:
Needs some minor tweaking to get the links to clear the frame rails, I'll hopefully get to that tonight.
:lmao:
Disassembled:
Screws installed:
