scx10 body guide
I found out the hard way that the Proline Ford Raptor body has a 13.3 wb. With the Iroks and the stock Honcho wb, gotta make a bunch of mods to the body. Still like tho.
all of the bodies built for the slash are right around a 12.5 wheel base, and nine inches wide. the stock ax10 with 2.2 inch tires was 10 inches. that would probably make a good fit considering those bodies were designed to work with a 2.2 tire.
has anyone seen a grand cherokee body for one?
Yes, I have but I can't find it now...been looking for it lately. I think it was a new bright body. One of the "senior" (experienced, not old) builders had one that was orange and I remember seeing one in some of the TTC builds that was green (I think).
*edit* I found it...it was one of War Pig's builds...of course a stellar build!
http://www.rccrawler.com/forum/showthread.php?t=134428
I wouldn't mind having one of those myself.
johnny 66 thank you for tanking time to make this old mam new be understand hope you see this . i coud not figuer out how to answer you.
I thought the proline 2 dr jk was for the dingo wheelbase and the 4 dr jk was for a honcho wheelbase
The Proline 4dr JK is a 12.3" WB and the 2dr is an 11.8" The stock scx10 and TR version have an 11.4" WB so you would have to use a slightly longer rear links, or use some spacers."thumbsup"
will the proline jeep 1992 cherokee. or the jeep 2009 2 door body fit a axial honcho wheelbase? thanks
in the FIRST POST I have it listed what bodies fit what wheelbases, in stock format did you even bother to check that?
Hi im new here.
Im thinking of Hpi Rubicon for my scx10. Will this Hpi Rubicon fit my scx10? Part no HPI106704 or this one ? HPI Jeep Wrangler Rubicon Body, Clear: S25, SAVX HPI7182
* my scx is extended like bender's with steering behind the axle. In process of building FoFF
Thanks.
(sorry if this Q hv been asked b4)
Pls help.
Hi im new here.
Thanks.
Pls help.
i had not posted the wheelbases for the hpi bodies yet, though i believe that most are 11.5 and fit the dingo wheelbase best. if you have modified you wheelbase then some one with the bodies will have to say the wheelbase, and if anyone can get me this number i will happily add them to the list. i may also add a new section with bodies that are not even close and the wheelbases for them.
