Shock Rebound
I like a fast front rebound and a slow rear rebound.
I get to be the 2 yr old again and ask why? Why fast up front and slow out back? How do you accomplish this? The benefit is?
I don't mean to over run this thread, but I'll bet many others are learning something here as well. I'll ask the stupid questions... I'm ok with that. Full circle now, like the original post, which setup that you run, then please explain the why's and how's that it is better than "stock". I'll up the ante as well by asking what are you trying to accomplish (either proven or theoretically performance related) by doing one of the "rebound" options listed in the OP?
Awesome info guys! I tried to research this and came up almost completely empty... I'm glad we have some knowledgeable people here! Sounds like i'm not the only one benefiting from this info, so that's great.
So, before i made this post i built my shocks to fully rebound as slowly as possible. I'm still going to try it out like this to see what its like, but i'm going to go back and build in 1/8th rebound. I'll let you guys know how it goes.
FYI, I'm running a almost fully custom RR10 Bomber with stock R2R shocks "thumbsup"
Always love to learn!
I'd have two questions for you then:
1. How much does your Bomber with battery on board weigh?
3. If you're set at full rebound, with your preload collars adjusted all the way up, how does it sit, any compression at all or do the shocks remain fully extended?
I'll get back to you tonight, I have a broken wheel and the new ones arrive tonight. So i haven't tested to the stance yet, but just from compressing them by hand, they feel about the same.
I'll check the battery also, it's just a 11.1V 3S Lipo
On a full size bypass shock, it is essentially multi stage damping based on the position of the piston, eg a triple bypass has 3 damping zones.
Your first zone generally is very lightly valved so its nice and supple over small bumps and imperfections. Another way to put it...slow speed damping.
The second zone is moderately valved. Vehicle speed has increased and that piston will float in this second zone most of the time. When its in this zone, it bypasses the first zone (where the name comes from)
Third zone is heavily valved. Large whoops, jumps and G outs will get a vehicle traveling at speed into this zone. Idea being that the damping slows down the shock piston velocity enough to minimize the chance of shock bottom out, supplemented with hydraulic bump stops. First two zones are bypassed.
To date, I have not seen an RC shock that performs the same functions as a true bypass and its not really the same as a "dual rate" piston that has been done in RC before. Any time you see people running a second shocks its usually for looks or performs some additional damping to the primary coilover.
*Sorry for slight thread jack:roll:
*Spring rate determines ride height, not damping
**Except if your shocks are hydrolocked...pogo stick!
I have thought about machining small grooves in the inner wall of shock body with varying end points would achieve the same effect but wouldn't be adjustable.
Oh man, i’m leaving it like this. The flex is perfect for crawling and it responds better then i could have ever hoped with these shocks when i lay into the throttle to get over an obstacle. Would definitely recommend it, i’m not even going to switch them back to try it out lol
Stance is about half an inch from full exstention
No collar pre load inflicted then?
No, i kept the collar in about the same place. The extra dampening i think is what is making the most difference with the extra rebound.
We’ll see if the seal holds up during abuse
Keep us updated on how that works for you. Thats a really good idea
