thecrusader
Anyone smoke there own meats? i have just converted
a weber kettle to a smoker and was wondering if anyone else
does it. there are a couple of threads on it in chit chat,i have looked
at them but theres not much. i looked all over the web for info before
i started,and there is a lot of conflicting information to say the least.
i was thinking some of us smokers could share some info.
wether to brine or not,wether you wet the wood and put it
directly on the coals or in tin,or even if you use coals or
something else. i am using briquettes,and was using hickory.
so far i have done some beef and a sausage in it. the beef was topside,
cut into two steak size chunks and submerged in "brine" 1 cup salt,3/4ltrs
water,pepper,rosemary and some vinegar. soaked for nearly two days,
washed, then smoked for about 4hrs at about 175 degrees. not enough heat i dont think.i am new to this,the brine i just made up,after looking on the net, tweaked it to what i thought.
do i need to brine the meat? or is it just for preserving? no doubt it
adds flavor, and makes the meat soft as,probably the way to go.
do i brine sausages? this might all sound stupid but im a newb.
help/input would be appreciatted. one of the problems i am having is getting
the temp right without it dropping off after half an hour. i think
the tiny bbq im using isnt helping,making it hard to regulate temps.
im going to have another go at it today or tomorrow.
so far i have been using hickory wood and about 10-12 briqquettes.
i have used foil and no foil,dry and wet wood.
here are my questions layed out from the babble.
*do i brine everything?
*is the wood suppose to burn? sounds dumb but i read somewhere,
you dont want it burning or it can taste rancid?i think me worrying
about the wood "burning" has made my life hard, constantly changing the wood chips when its maybe not needed.
*to use alfoil or not
*to use dry or damp wood chips.
heres some pics.
the weber i have i only use the bottom grill to hold the coals,
and have made two hooks in the roof to hold the meat inside
the lid, near the thermometer i fitted, havnt seen this done before,works great. if anyone else has a smoker or some tips,post em up, that would be awesome.
thanks in advance.
this next photo looks like a porno shot from E.T.
is actually a Cumberland sausage.
cheers.
heres some pics.
thanks in advance.
cheers.
