Sneak Peek Losi 2.2 Rock Claws
Bender,
You missed your calling. You need to write porn. The way you were describing the tires...I got all worked up..:shock:
"They are the softest foam available, and I figured the combination would work very well together. I immediatly headed over to an area known for tough steep vertical faces. I turned the radio on, plugged my battery in and pointed the front wheels towards the first climb. My rig walked right up the steep off camber face with zero drama. I was blown away. Time to try a few more tricky spots. Next was a big undercut that front tires struggle to get traction on. I approached the obstacle at a slight angle, the front passenger side tire grabbed instantly and pulled the front end up to an almost vertical position. I gradually eased on the throttle and the front tires dug in as my rig crested the climb with relative ease. By this time a few more local guys showed up and were pointing out obstacles everywhere to try. "
I think Hustler is looking for a new editor.
Seriously though, They sound and look great. My set are on backorder.
Thanks
John
"thumbsup"
Bender,
Thanks
John
"thumbsup"
LMAO!! :lol:
Thanks. 8)
Damn these tires are amazing , cant wait to get on a set, anyway we can get a rule that says benders not aloud to use any tire made after 2000???
:lol:
:lol:
Better hope your Rock Claws show up before the next comp. :twisted: :lol:
"thumbsup" the losi rock claws are awsome I run them at our comp this weekend and they sidehilled,climbed perfect you could not ask for a better tire this tire has for sure steped it up a knotch. It is the tire to run in my opinion"thumbsup"
pfft.........I don't think they helped at all!
He only won by 59 points (3x gate courses w/ 40 max)
:shock:
