Spiitz Travsky
If you can get ahold of one of those servo mounts that brings the servo over to the gear case. It will allow you to move the front axle link shock mount in to the inner holes.
Josh, I will be picking up some of the NCD accessories from Tomi when he gets back in April. Not sure if his servo mount will provide enough room to move the mounts in to the next set of holes. It seems pretty close to the gear case on his build, but it does not look like he could move the mounts in any further based on his photos.
I run the front uppers towards the outside at the chassis and the rears to the inside at the chassis.
Rowdy, Thanks for the tip! I flipped the back upper ball ends around and I can lift any wheel higher now before the other axles starts to lift. Is that why you like that seup?
Erik, It turns out I was just being a newb! Your FL links will work just fine as is. I played with the rod ends a bit more and was able to get a much better position. I rotated them 180 degrees so the bend was reversed. This solved all the binding issues I was having and looks like it will protect the gear case better too.
Is this what you originally intended with your bend?
Just checking to make sure I am finally getting it right. Seems better to me at least.
I ran into another area where I think I will need some advice. I was trying to install the HH motors, but of course I have never done this part before, and there is not a lot of detail in other threads on how it is done.
I put the the pinion on where it would meet with the gear fully.
I noticed that the mounting holes on the motor are not tapped and they did not come with any machine screws. How do I mount these motors? Are they meant to be tapped or self tapped and what size screw do I need to get?
Thanks for all the advice and support so far! I will keep trucking along.
