Spur gear help
Yes that's exactly the one that is needed if anyone stumbles across this thread in the future. I found that out after I ordered a plethora of spurs for fitting. They also fit the rc10gt associated trucks and likely others. I ended up using the Kimbrough 239 60t. The gear cover can still be used and it does NOT required the shaft hump to be completely cut out. Just sanding down a bit with a Dremel for clearance.
