SSD wide diamond axle install instructions?
oosel
sturgis
I just received my SSD wide diamond centered rear end. It did not come with install instructions. I cant find install instructions anywhere online. Does anybody know if install instructions exist? I could probably figure it out but I like some instructions to follow just incase I miss a step lol.
There are no instructions. It is easy. Just use your Axial manual as a guide line. Remove links and shocks from the axle. Remove the stock diff from the axle. Install the diff in the new SSD axle. Install the new axle shafts with stock bearings. It uses a larger bearing for the output drive I believe though. Reattach links and shocks and you are good to go.
Just reinstall the diff the same direction (gear on the same side) so the wheels spin in same direction.
Got it installed. It was not as confusing as I thought. Took me a while to figure out what all them screws were for that came with it. They were for the brackets that mount to the axle. And one long screw for where the links mount to the axle. Other then that it went smooth. Seems like a quality built part.
