Tommy R
Wow, all that from just a tune and the same cam? Impressive! So....what were the numbers?? 8)
lol read slower. we REMOVED hp, not gained.:ror: to gain drivability.
although some of it was due to age im sure. the original tune was when the new LME short block and internals were brand new.
my gears also hurt the dyno numbers as well. which ive never understood, i would have thought they would helped. ive heard even just my 12 bolt vs the stock 10 bolt reduces dyno numbers as well.
went from 432 to 403. with 13% driveline loss that puts flywheel hp around 455. less than id hoped, but it still puts a smile on my face.
stangkilla what suspension setup you running? ive been somewhat distracted by other things in life but with my fbody my intention is keep the motor stock (aside from longtubes) and focus on the suspension to make a fun to drive car.
i havent been on ls1tech or any fbody sites for years to read suspension tech, but when i was up to date it seemed the strano setup was the hot ticket for both autox and street.
couple years ago i had the strawberry milkshake happen and replaced the steering pump with a turnone unit, if you havent done that yet it really changes the steering feel from an old caddy to something a little more racy feeling.
yeah I forgot how expensive this 1:1 shit is!:shock:I know I'll be hooked and talk about expensive hobbies!
that and Motul 600 are the two im looking at. I do like the superblue for my scenario so I can see when ive flushed 100% of the old fluid out.
also looking into ducting.
you should edit your initial post to have your current setup and update it as you go.
are the bmr's the same as stranos? i only know what i read but from what i gathered the strano setup was good for autocrossing and stuff while not dropping the car all that much. do the bmr's drop lower or are firmer or something?
