wings_of_fire
When working with 50 A to 60 A, keep your argon flow between 7 to 10 liters per minute. Argon regulation is important with the amperage. Argon creates the plasma effect that melts the metal.
When your arc is on, you will see a small melted pool just in front of the tungsten electrode. Try to move that pool with the tip of your electrode. Once you are properly able to move the pool with your electrode, then start with the filler rod. Initially use a thin filler rod of 1.2mm (0.047 ") diameter. Once the pool is formed, tab tab tab with the filler rod in a rhythm. Say 'Tab' verbally, so that you get into the rhythm of using the filler rod.
There will come a time when tig welding becomes a second nature to you. Then the fun begins.
