therealrsr
My crest is about a week old and going to be my first crawler, I have many bashers, mt't, buggies, road, helis and a single old school trainer plane so not much I won't understand in explanations. (saving you all some typing I hope)
So far I have:
m3 screws where prone to loose or already loose
flipped batt and elec frame supports Bender stage 1
inverted shock mounts Bender stage 1
Trimmed stock tire tread Bender stage 1 (ordered axial 2.2 XR10 vws beadlocks, Hot Bodies Sedonas, Memory foam)
Drilled out wheel holes to 1/4"
Painted 2 Door Proline Rubicon Body
Ordered "throw away" Atomik 35t and Axial 55t motors to determine which is right for me (either move to a rebuildable brushed or a sensored brushless after deciding)
Super soft (red) axial springs
Plastic balls replaced with alluminum
Axial stage 1 alum link kit
Swapped in one of my Spectrum rx's (Stock was actually ok, just used to tx programming)
Savox High Torque Metal Gear servo
Axial 25 t alum servo horn
And...
Unfortunately ordered the steering kit for the old AX10
So instead I replaced the top steering link with an adjustable toe link from parts box. Stock plastic link between wheels. I read through all of Bender's crawl build and his early comment about having some steering flex made sense to me, but then he swapped for rigid in stage 3 anyway.:?: I have looked at the vanquish, strc and rc4wd options. Not sure which route to take so looking for input. Seems Vanquish has the best rep around here, but also more $$$. Most importantly, do you want steer flex in a crawler?
run 5700 mah 2s and stock 20t for now. LVC, 100% drag, 100% brake, for/rev w/ no lockout.
For future I'm thinking BEC, vanquish axles, axial alum knuckles-c hubs-carrier kit for XR-10 (AX30432), more wheel weight and a smaller/lighter lipo.
Crawling skills improving every day with practice/line selection, this is a very different driving experience but I love it. There is a late Sept crawl comp hosted at my lhs that I would like to try...and probably get schooled. So please help guide a newb crawler to a better than last finish:lmao: Thanks!
So far I have:
And...
