STOCK specs for Axial RTR Honcho
DieCastoms
Eastern Georgia, USA
Hi all. I've started this thread to keep track of the stock specs of the Axial Honcho RTR. if you know any I don't already have, include them and I will continue to update this first post. Please correct me if anything is wrong of you have more accurate info!
Code:
Shocks:
  Over all length, 72mm END to END (NOT eye to eye)
  12.5mmx20mm  3.6 pounds/inch  "super soft" (red)
  12.5mmx40mm  4.08 lbs/in  "medium* (green)
Steering servo:
  132 inch ounce
Axle Bevel gears
  38/13
Transmission
  87/20 48p
Bearings
  5x11x4
  11x15x4
Motor
  27t
  RPMs?
  Torque?
ESC
  6c Nickle, 2s LiPo
  19t limit
  106amp peak
  BEC voltage/amp 5v/2a
Suspension Links
  Front
    Upper 112mm
    Lower 130mm
  Rear
    Upper 122mm
    Lower 130mm
springs length:
Sorry i know this is not relavent but If I wanted more torque out of the stock motor can I just lower my pinion? Great information BTW.
It won't actually change the rated torque of the motor but will give more low end pull. It will also slow the truck down. I've experimented with pinions on the stock motor using 16, 14, and 12 tooth pinions. I still wasn't happy. I ended up with a 35 turn motor and a 12 tooth pinion. More torque and a slower speed and it climbs well. It also lowered my motor and esc temps by a bunch.
I'll try the 12 t for now. You think 12t and 45t motor is a good combo?
Yes, that should give you a lot of torque and keep your operating temps in a good range. I'm going to try a 45 turn motor in a truck I'm building now and will stay with the 12 tooth pinion.
Not all of it. Just been compiling stuff as I have to look things up, and as I hear things here and there. Figured it would be worthwhile to someone, somewhere, somehow, someday :P
DieCastoms (Michael)
